RailClone => RailClone Pro (*) => Topic started by: djibvongenf on May 15, 2022, 07:14:30 pm
Title: Pavement conform problem
Post by: djibvongenf on May 15, 2022, 07:14:30 pm
I followed a tutorial about pavement and i cannot make the pavement conforoming to a selected surface. I have to add subdivision to the pavement to make it look it does work but first it's wrong and second it does not really work.
Im joining the .max maybe someone could help
ty
Title: Re: Pavement conform problem
Post by: Dragan on May 15, 2022, 08:24:29 pm
Hi.
Can`t open the file due to the Max Version (please always try to save the file for the lowest Max version you can so more people can open it)
However, mostly the fix will be to make the surface a little big larger to overlap the generated geometry. (Edit Poly>Poligon>Outline)
Post by: djibvongenf on May 15, 2022, 09:08:37 pm
Hello, thank you for your support. Here is a 2018 file, hope you won't be shocked by the high level of understanding of railclone :)
Post by: Dragan on May 15, 2022, 09:25:07 pm
Yup, just outline the surface seems to fix it.
Post by: djibvongenf on May 16, 2022, 07:54:22 am
Hey thank you very much for your quick help!
