Author Topic: Paving distorting at edges  (Read 3449 times)
Terri Brown
    • Terri Brown 3D
« on: November 09, 2018, 07:46:03 am »
I've tried to search if this has already been posted, but can't find anything related. If there is a thread already there please point me in the right direction.
I'm having issues with my cobblestone paving distorting on the surface edges. It seems to work fine on flat surfaces, but with the sloped ramp I have issues on both edges. When I adjust the spline to align with the surface exactly I get another type of distortion. Please see screenshots attached, and let me know if there are any other settings you need to see. The setup is super simple.
Cheers,
Terri
Re: Paving distorting at edges
« Reply #1 on: November 09, 2018, 07:51:08 am »
When using surfaces in RailClone make sure surface is bigger than clipping spline. Most of the times that will need to be scaled and set to non renderable object to work as expected.
Terri Brown
    • Terri Brown 3D
« Reply #2 on: November 09, 2018, 08:13:54 am »
Thanks Rokas. Just found this thread...a bit too late  :-\ :
https://forum.itoosoft.com/railclone-pro-(*)/railclone-surface-question/msg12179/#msg12179
