Author Topic: Railclone 4 Segment Material and Vray GPU Problem  (Read 3839 times)
adiaz
« on: November 18, 2019, 05:48:33 pm »
It seems like the "Use Segment Material" feature is not yet supported for VRay GPU rendering.
Please see attached sample image. The single-colored yellow cars were placed with a linear 1S distribution in railclone, over a simple straight spline. The other cars are instances, placed manually.
Is this something for you guys to fix/incorporate or is this something Chaos Group should address?
Thank you.
« Last Edit: November 18, 2019, 06:07:05 pm by adiaz »
Re: Railclone 4 Segment Material and Vray GPU Problem
« Reply #1 on: November 19, 2019, 08:43:42 am »
For V-Ray GPU it must be implemented by ChaosGroup (i will send a note to them, to remember it).
Currently this feature works only in V-Ray standard and Arnold, the render engines which actually support third-party plugins.
