Author Topic: plank cladding 9  (Read 3563 times)
LM1206
plank cladding 9
« on: September 16, 2019, 05:39:00 pm »
I am working with plank cladding 9 but this likely applies to all plank cladding presets.
I can use global scale to get the size that I want, but I would prefer to go into style editor and set the exact Y size.
When I set the  height of the plank to 4" in the fixed size parameter for instance, the planks start to overlap one another.
What can I do to scale the plank to exactly 4" in width and keep space between them.
Changing the padding seems to have no effect.  I would also like to be able to control the distance between the planks. Is there any way to do this?
Re: plank cladding 9
« Reply #1 on: September 17, 2019, 12:28:43 pm »
Adding a Transform Operator (for example, with the Y Fixed Size parameter exported to have the control over this size directly from the UI) between the used Segment and the Cladding macro should do the trick. Attaching a sample scene.
