Author Topic: UVW XForm rotate about center  (Read 5273 times)
UB8512
« on: March 14, 2018, 10:46:12 am »
Hi, it is posible somehow rotate UVW about center inside RC? I have texture atlas with wood ends. It works fine with max UVW XForm, but it is missing in RC ver. Thanks.
Re: UVW XForm rotate about center
« Reply #1 on: March 14, 2018, 01:08:26 pm »
Hi, Thanks for the suggestion - I've added it to our wishlist.
In the meantime, you can get around this by following this procedure:
1 - In the Material Editor > Map parameters, offset the map by -0.5 on the U and V axes
2 - Select the end polys on the source object and apply a UVW XForm modifier. Set the U and V offset parameters to 0.5 scene units
That move the centre of texture and UVs to the origin and rotation should then work as desired. I've attached a file to illustrate.
Best wishes,
UB8512
« Reply #2 on: March 14, 2018, 01:58:47 pm »
Thanks for example, it works like a charm now. I will be waiting for RC update too  ;)
