Author Topic: vertical panels with decreasing distance  (Read 4757 times)
M55
« on: March 19, 2018, 02:13:51 pm »
i want to create vertical panels with decreasing/encreasing distance as in my example screen.
i have done the macro tutorial with encreasing rotation but can´t figure out how to adapt the process for decreasing distance
input value for the first distance and the decrease (linear or better logarithmic) should be possible
« Last Edit: March 19, 2018, 02:28:20 pm by M55 »
Re: vertical panels with decreasing distance
« Reply #1 on: March 20, 2018, 11:15:00 am »
You might find interesting this related thread.
One of the possible ways would be to define the X Size of an empty Segment (linked to the Sequence Operator) by the Arithmetic Operator – in a similar way you may drive the Left / Right Padding value(s). In case of using two Parameters (like Start Distance, End Distance as in the attached sample scene), the expression should be following:
return Input1 – (XsectionPosition*Input2);
Please feel free to use the bundled macro “Increment by X Position”.
In case, you’re interested in controlling the Z Size (or Z Scale), you can use the same principles to drive the Transform Operator. Hope that helps.
M55
« Reply #2 on: March 20, 2018, 11:30:53 am »
Hi Michal,
thanks for the demo scene and the link to the cards thread. i will have a look at both and try to learn and learn and learn .... and some day ...
Klaus
