Author Topic: Prevent geometry overlapping on corners  (Read 2675 times)
Keith678
« on: December 03, 2021, 07:42:06 pm »
Hi guys,
So I recently purchesed Railclone and following some tutorials to get use to it. (this one - https://www.youtube.com/watch?v=Xe0MPT0S0wI)
One big issue I had before I had railcone, was when using sweeps for paths, it would overlap some of the geometry at corners. However Railclone seems to be doing the same thing.
The sweep actual does a better job here but I'm sure I'm not optimising my workflow.
Any tips or help would be great.
Keith
Keith678
Re: Prevent geometry overlapping on corners
« Reply #1 on: December 03, 2021, 08:11:43 pm »
So I've noticed that even though they overlap they don't seem to effect the render itself. but the dropped section looks strange
Keith678
« Reply #2 on: December 05, 2021, 09:11:19 pm »
https://docs.itoosoft.com/kb/railclone/overlapping-issues-on-rounded-corners
The first step of increasing the interopolation steps to 100 helped with this issue.
« Reply #3 on: December 06, 2021, 09:46:08 am »
Glad to read you found a solution. There is a limit on how wide a pavement can be before the edge loops intersect (basically no larger than the corner's radius) but apart from that, Curve Steps can really help.
Best,
