RailClone => RailClone Pro (*) => Topic started by: RL1396 on May 02, 2018, 02:01:56 pm
Title: problem random size
Post by: RL1396 on May 02, 2018, 02:01:56 pm
When I create a random for the size of the slats, they do not put end to end but are spaced. How to make them follow each other?
Title: Re: problem random size
Post by: Rokas on May 02, 2018, 02:14:53 pm
You should switch the x with y.
Attached simple scene. If that does not help- please attach Yours and I will explain in more detail.
(https://i.imgur.com/H1cX4zO.jpg)
Post by: RL1396 on May 02, 2018, 05:39:04 pm
I don't think this is the problem.
Here's my file
Post by: RL1396 on May 02, 2018, 07:29:26 pm
Thank you. It's the good solution but I wonder why the X/Y axes are in the wrong orientation.
Post by: RL1396 on May 02, 2018, 11:11:33 pm
By doing identical tests, I find myself facing different situations. In this case, the boards should have lengths between 50 and 100% of the initial length. Why is not the case?
Post by: Rokas on May 03, 2018, 08:01:39 am
Reset your Box001 xform. That should help.
Please attach your scene if it does not.
Post by: RL1396 on May 03, 2018, 04:03:57 pm
it doesn't work with "reset xform"
Post by: Rokas on May 03, 2018, 04:13:10 pm
You have wired Random number 50-100 to Fixed size. I would suggest to set this parameter as Scene Units. It makes more sense.
If You want to adjust by percentage, You can do that in transform node:
(https://i.imgur.com/YzIfYTa.jpg)
