Author Topic: Variant width along the alignment.  (Read 3101 times)
linhkts
« on: November 23, 2016, 03:42:15 pm »
Hi there,
I have a modelling task of a pedestrian bridge that requires changing width along the bridge's alignment (Please see the attachment for section/plan of the bridge). My question is if it is possible to accomplish my task with Railclone (mine is 2.7.4)? If yes then could you provide some instructions? I was looking at Itoo tutorials and have only seen the ability to change height along the alignment. I am new to the software.
I have attempted to spit the bridge section in pieces and at very least, I still need to be able to make the wood planks change their widths along the alignment.
Thank you,
« Last Edit: November 23, 2016, 03:52:53 pm by linhkts »
Re: Variant width along the alignment.
« Reply #1 on: November 23, 2016, 05:48:24 pm »
Well, as mentioned in this "Road creation width" related thread - "the scale is not progressive", but it might be possible by dividing it into separate parts.
I would suggest you to try split it into three generators:
(1) For sides, using two "border" splines
(2) For boards, where creating and using a "centre" spline and a closed spline (made from "border" splines) as a Clipping area would be recommendable
(3) For support structure, using the "centre" spline
Hope that helps.
Best regadrs,
linhkts
« Reply #2 on: November 23, 2016, 09:40:59 pm »
Michal,
Thank you for your suggestion. I will try that and come back with the result/issues. Gotta go through a learning curve here.
Prior to posting to the forum, I have employed similar approach to your suggestion and converted the rail clone objects to Editable-poly to move parts manually. It looked ok from afar but close-up views were unusable. I am trying not to convert to editable-poly this time.
