RailClone => RailClone Pro (*) => Topic started by: HB2523 on October 19, 2017, 06:45:39 pm
I'm trying to create a pavement around my building. But the slicing of the geometry does not work out properly when it comes to sharp turns. The meshes tends to intersect, overlap and deform rather then being sliced. I've tried the same thing with your presets for pavements in RailClone, and they have similar problems.
See the attached images for examples. In my own example I've designed the pavement with a seperate RC object using the Array 2S.
I would suggest you to switch the Generator's Y Mode to Free (attaching screen-shot). Adjusting the Style > Curve Steps option might be needed too. Hope that helps.
I've tried this now, but it didn't help. Could you provide me with a sample scene?
