Author Topic: Problematic corner  (Read 8960 times)
Paulo R. Beck
Problematic corner
« on: May 20, 2014, 02:05:01 am »
Hello
I'm trying to make this corner of this building, but I'm not getting ...
What am I doing wrong?
Re: Problematic corner
« Reply #1 on: May 20, 2014, 09:34:46 am »
Hi Paulo,
I've attached a file with a version of the building style you are creating. I've made a following changes to get the corners to work.
  • Removed the sequence modifier and used the blank wall only in the default input. Then add the windowed wall to the evenly input, the spacing for this can be adjusted using the generator > Rules > Evenly distance value. Using evenly instead of sequence should prevent windows getting clipped on the corners
  • Since your corner segments are the same as your default segments you could remove the corner completely, the default section will mitre correctly in the corners (the same is true of the start and end sections). If the corner sections need to be different however then scaling them on the X axis gives them adequate length to correctly bend around the corners.
  • Set the mode to scale, not necessary but means that default segments will always scale between evenly segments which can produce fewer segments in certain circumstances.
I hope that helps, if you have any further questions please let me know.
Kind regards,
« Last Edit: May 20, 2014, 09:37:23 am by Paul Roberts »
