Author Topic: surface problem  (Read 3258 times)
lukx
    • lukxCGI
surface problem
« on: July 17, 2016, 07:39:30 am »
I got problem when using surface node:
Re: surface problem
« Reply #1 on: July 18, 2016, 11:56:24 am »
RailClone uses surface by projecting the geometry along the RC object's local Z axis, so you will get better results if you align the object so that as much of the surface as possible is perpendicular to this axis. In the attached file I've rotated the object as you can see here:
I've also turned on the Segment's Align Y with Surface option so that it deforms to follow the curvature of the surface on the X and Y axes.
Many Thanks,
