Author Topic: Transform segment along a spline  (Read 5260 times)
Gabriel
« on: October 07, 2015, 01:09:54 am »
I was wondering if there is a way to transform the same segment along a path. For example I would like its scale to be 100% at start but to get gradually smaller by the end of the spline. I have tried playing around with the plug in but I haven't managed to have success.
Thanks in advance
Re: Transform segment along a spline
« Reply #1 on: October 07, 2015, 11:24:19 am »
Hi Gabriel,
To do this you would need to use an expression that will rescale the object based on it's position along the spline. To do this follow these steps.
  • Create a new Transform operator and wire the it between the segment you wish to rescale and the generator
  • Right click on the Transform operator and export the Fixed Scale X,Y, and Z properties
  • Create a new Arithmetic node, wire it to the Transform  nodes exported scale parameters and set the mode to Expression
  • Create a Numeric node for the start scale value and wire it to the Arithmetic nodes 1st input
  • Create a second Numeric node and wire it to the Arithmetic node's second input. You will now have a graph like the image below. New nodes are shown in red
  • Finally we need to add the expression. In the Arithmetic node, open the expression editor and enter:
    (1-XSplinePosition)*Input1 + XSplinePosition*Input2
    This expression is using the segment's position along the base spline to gradually transition between the start value (Input1) and the end value (Input2). XSplinePosition returns a scalar between 0.0 for the start of the spline and 1.0 at the end, so it can be used as a multiplier to gradually increase [ XSplinePosition*Input2] and decrease [(1-XSplinePosition)*Input1] values. By adding the two halves of the equation together we get a transition from one state to the next.
I hope that helps, please see the attached file for this example.
Many thanks!
To learn more about expressions, check out Chapter 3 of our new RailClone guide.
Gabriel
« Reply #2 on: October 08, 2015, 01:43:25 am »
Oh I see! Thanks a lot for your help Paul.   :D
Yuriy Bochkaryov
  • CG Artist
    • https://ybochkaryov.com
« Reply #3 on: October 12, 2015, 04:44:20 pm »
Is it possible to have more control points? Not only start and end, but some in the middle.
Mail:     info@ybochkaryov.com
Skype:  Hunter-3d
https://www.instagram.com/yuriy_bochkaryov/
« Reply #4 on: October 12, 2015, 06:17:41 pm »
Though it is possible, it's a little bit fiddly at the moment (see attached).
In future versions we hope to make this process simpler, possibly using transform markers placed along the spline.
Many thanks,
Yuriy Bochkaryov
  • CG Artist
« Reply #5 on: October 12, 2015, 06:23:53 pm »
thank you!
Skype:  Hunter-3d
Yuriy Bochkaryov
  • CG Artist
« Reply #6 on: October 14, 2015, 02:07:20 pm »
Hi Paul,
I made some tests...
If start scale is higher than 30% - everything goes wrong
Please see the screenshot - http://clip2net.com/s/3oKF6o5
Skype:  Hunter-3d
« Reply #7 on: October 14, 2015, 03:27:50 pm »
You're right, there was a mistake in the graph. The attached version should fix it.
Many thanks,
