Author Topic: random noise texture  (Read 2978 times)
muoto
« on: July 26, 2020, 02:38:28 pm »
i would like to have a noise texture that is randomly placed (different scale, offsetà on copied objects with railclone.
Any ideas ?
I have the impression Vraymultisubtex doesn't work (or new in latest version?)
I tried also the new uvw random from vray5, but no luck
Re: random noise texture
« Reply #1 on: July 26, 2020, 05:42:07 pm »
« Last Edit: July 26, 2020, 07:22:08 pm by Dragan »
muoto
« Reply #2 on: July 27, 2020, 11:37:12 am »
Well, actually, i want the noise pattern to be different on each of there rectangles. Here you see that the noise pattern is actually going from one rectangle to the next one.
« Reply #3 on: July 27, 2020, 11:56:45 am »
If You are using procedural noise map, then You can use Explicit Map Channel to make randomization work:
Hope this helps
muoto
« Reply #4 on: July 27, 2020, 12:16:54 pm »
wonderfull !
