Author Topic: Quadmenu missing 3dsmax 2023  (Read 3266 times)
reccio
« on: May 25, 2022, 01:05:31 pm »
Hello i recenlty upgrade to 3dsmax 2023 and install the new version of railclone, and it does not show the selection menu on quad menu. I saw a old post with someone who had the same issue, i tried to disable the script protection etc... and it does not show.
\AppData\Local\Autodesk\3dsMax\2023 - 64bit\ENU\usermacros has the Raiclone RailClone-RC_MS_SelectBaseObject and RailClone-RC_MS_SelectSegment, correctly.
I hope it can be solved, i currently dont have any other computer to test it.
Thanks in advance.
Vladimir
Re: Quadmenu missing 3dsmax 2023
« Reply #1 on: May 25, 2022, 02:12:55 pm »
Check this thread https://forum.itoosoft.com/forest-pro-beta/3ds-max-2023-issues/
I think this is the same story.
reccio
« Reply #2 on: May 25, 2022, 05:58:00 pm »
What it sees to work is copy all the RC .mcr files to C:\Program Files\Autodesk\3ds Max 2023\MacroScripts. Now i have the quadmenu back.
reccio
« Reply #3 on: May 25, 2022, 06:27:33 pm »
Thanks for your reply now i see that the forest pro menu is also missing.
« Reply #4 on: May 26, 2022, 12:11:46 pm »
Please try manually execute the railclone_utils.ms locaed under C:\ProgramData\Autodesk\ApplicationPlugins\RailClonePro2023\Contents\scripts\startup by using Scripting > Run Script... - in the case of the Forest Pack plug-in, it's handled by forestpack.ms located under C:\ProgramData\Autodesk\ApplicationPlugins\ForestPackPro2023\Contents\scripts\startup.
