Author Topic: question about clipping  (Read 2649 times)
BL_zoomvp
« on: March 09, 2023, 02:56:57 pm »
Hi.
I've got a question about the clipping feature.
Somehow I've got different results in my railclone.
In the first image you can see my problem, that on the left side the clipping works as intended, but in the right side the segments are not cutted.
Where have I done the mistake?
I've got a railclone along radial splines aswell as a surface area, and a clipping spline as well.
I hope the other images provide enogh information.
Thank you very much in advance!
best regards
BL_zoomvp
Re: question about clipping
« Reply #1 on: March 09, 2023, 03:08:45 pm »
Ok.
I solved the problem by redrawiing the right part of the spline.
« Reply #2 on: March 10, 2023, 12:08:15 pm »
Glad to hear you fixed it. We used the Boolean function provided by Max and it can be a bit unpredictable. Unfortunately as its a Max function, we have little control over it, but sometimes I've found that simply reselecting the graph is enough to fix it.
Cheers!
