Author Topic: question with y-evenly  (Read 33193 times)
AldingerWolf
« on: December 04, 2013, 04:45:29 pm »
hello,
we are new to railclone and try to make a facade that we already constructed manually before.it´s the upper part of the facade. the lower part i will do with another RC-composition.
on the picture you can see on the left side how it should look, and on the right side you can see the result of railclone as i get it done.
so what my problem is, that i don´t get the sides fixed. the y-evenly always gets complete to the edge.it shoul´d stop at the right/left side object...
any tips to fix this?
thanks for help
tomes
Re: question with y-evenly
« Reply #1 on: December 05, 2013, 05:47:29 am »
Please, be sure that Y Evenly->Extend to Side is off.
AldingerWolf
« Reply #2 on: December 05, 2013, 08:54:41 am »
thanks carlos
it´s better now, but still not what i want. i attached also the maxfile
thanks for your support
AldingerWolf
« Reply #3 on: December 05, 2013, 09:13:13 am »
next question is to the down part.
if i pick the x-evenly the default-object glass dissappears.
also i cannot get the x-evenly-colums to the sides where i want them to be. see the facade on the left for how it shoul´d look.
here again a maxfile attached
thanks again for looking in. i´m very interested in the solutions. i think for you it´s maybe a klick away ;-)
thanks carlos
« Reply #4 on: December 05, 2013, 09:51:40 am »
All segments in a same row should have the same height, if not there is no way to fit them. In the first scene, Y Evenly is larger than Left/Right Sides. That's the problem.
I've attached a variation using two Sequences on Y, instead using Evenly. I also removed the Y Spline, and replaced it by Generator->Y Size and Generator->X Rotation=90. In this way is simpler to set the building's height.
Same problem with the X Evenly scene: all segments must have the same height.
AldingerWolf
« Reply #5 on: December 05, 2013, 10:01:19 am »
thanks carlos, i get into it.
whats with the colums at the edges? how can i get this? possible or not?
AldingerWolf
« Reply #6 on: December 05, 2013, 10:23:27 am »
hello carlos,
i don´t want to do it over sequences, because it´s no regular sequence !   behind the y-evenly there are the floors and i want to have the flexibility of the y-evenly. and for further projects with other floor-heights
so if i modify the objects to the same height i don´t get the right result. either i need a y-evenly to extend to the edge but with staying fixed default axis, or i woul´d need an y-evenly object for the sides !
this is i think not possible to do...maybe you say other.
« Last Edit: December 05, 2013, 10:34:21 am by AldingerWolf »
« Reply #7 on: December 05, 2013, 10:42:02 am »
An alternative solution is to use two generators, so each one may have different segment's heights.
Please, see the attached scene. In the first generator i've used a empty segment (with padding), to create the column's gap. Same procedure may be used for the main scene.
AldingerWolf
« Reply #8 on: December 05, 2013, 12:16:04 pm »
no license free   ;)  . i can´t check but come back if i have...
can you please look into my questions of reply #5  and reply #6 .
thanks carlos
« Last Edit: December 05, 2013, 01:10:34 pm by AldingerWolf »
« Reply #9 on: December 05, 2013, 05:09:23 pm »
Please, see my previous scene. The multiple generators solution may be applied for #5 and #6.
It's not possible to customize the side piece of a Y Evenly row (in this case it must have different height), so the idea is to "overlap" multiple arrays in a same position using several generators.
