Author Topic: Rail Road Problem  (Read 40042 times)
sg
Rail Road Problem
« on: September 17, 2013, 01:28:23 pm »
Hello.  I ran into a proplem while creating railway.  The path changes in Z direction and has diffrent turnes.  The main problem is unwanted inclination on straight and  turn parts of the spline.  I used adaptive deformation.  Also tried  Vertical and Stepped but axes then were straitened along z axis everywhere  and didn't conform the direction of the path. Need Help!
Re: Rail Road Problem
« Reply #1 on: September 17, 2013, 04:11:56 pm »
It should work fine using Bend + Vertical mode. Please, send us a test scene, we'll check it.
sg
« Reply #2 on: September 17, 2013, 05:11:00 pm »
Thanks for fast reply. I've tried to use bend + vertical  that partially solved the problem of railways tilt, but they a now deformed too obvious. I've attached the scene.
« Reply #3 on: September 17, 2013, 06:04:54 pm »
Is there some specific frame in the animation to see the problem clearly ? The path is very long...
By the way: in the wooden generator set "Rules->Corner->Vertex type" to other type than "All" (i.e. Corner or Bezier-Corner). If not, the Corner rule breaks the paths in sections at each vertex, creating strange gaps between the evenly segments. Also i suggest to turn off "Evenly->Justify" (it has no sense here).
sg
« Reply #4 on: September 17, 2013, 06:13:59 pm »
Frame 3839 from Camera_Work. If  Bend+Vertical is turned on - axis and rails skew
« Reply #5 on: September 17, 2013, 06:28:31 pm »
Ok, i see. I'm afraid there is not solution for that. In this case should be necessary an independent control for banking; a feature which is in the wishlist, but not available yet.
