Author Topic: Spline issues  (Read 4271 times)
Adi S
Spline issues
« on: October 08, 2020, 02:36:58 pm »
Hello guys ,
I often have issues with Splines that are not on Horizontal plane (X,Y) which causes situations like on attached image. Only solution I could find is to redraw spline, but if there's any Script or other faster hack that will help, it would be highly appreciated. In this case it's simple to fix it but with larger splines it takes time to fix it. I'm guessing this is a MAX Spline issue.
 Here I'm using a Linear 1S generator with one box segment and 4 splines for four different side.
Re: Spline issues
« Reply #1 on: October 08, 2020, 04:44:59 pm »
would You attach a maxfile to illustrate the issue?
Adi S
Re: Spline issues
« Reply #2 on: October 08, 2020, 08:18:50 pm »
Sure, here it is. If you Reverse that particular Spline , it will look ok and rotated 90 degrees. For other Splines , if you reverse it , they get flipped , as I would expect.
Re: Spline issues
« Reply #3 on: October 08, 2020, 11:39:53 pm »
1. Orient your segment part on the X/Y plane.
2. Make the RC Icon parallel to your Spline.
Adi S
Re: Spline issues
« Reply #4 on: October 11, 2020, 11:42:53 am »
Worked well, thanks a lot!
