Author Topic: RailClone 4 Macros  (Read 9554 times)
RailClone 4 Macros
« on: December 04, 2019, 09:17:43 pm »
Hi, as far as I can see, a lot of community members have a problem with windows.
I would like to share the macro I did during the RC4 Beta test.
The macro creates a window frame that can be open, tilt, slide, etc. Basically All-In-One  ;)
The video on the link shows how everything works.
https://www.youtube.com/watch?v=QTGXqxQVI-E
As the macro emerged during beta testing, the number of parameters increased as the Beta progressed so it is quite complex and maybe not suitable on the large scale projects. Also, there is a possibility that there may be a bag or two so please report it and I`ll try to fix it.
Anyway, I hope someone finds it useful.
Scene contains 3 RC object:
1. Based on the X/Y size.
2. Based on the Linear Spline and Parameter for Y Size (could be used with Marker workflow to use user data for e.g. Y Size)
3. Based on the Clipping Spline (First Vertex should be at the bottom left corner of the spline segment)
Best Regards.
« Last Edit: December 04, 2019, 09:24:53 pm by Dragan »
JG_archviz
    • JG
Re: RailClone 4 Macros
« Reply #1 on: December 05, 2019, 08:46:03 am »
Thank you --- the video is also good for explaining things :)
DT2656
« Reply #2 on: December 05, 2019, 09:21:54 am »
Excellent work!!!  :)
« Reply #3 on: December 05, 2019, 09:24:43 am »
Yes. Although there are some description notes.
« Reply #4 on: December 06, 2019, 10:49:12 am »
Thank you, Fill free to ask if you need some more info.
Best Regards
TL1895
« Reply #5 on: January 21, 2020, 06:52:26 pm »
That is fantastic! Thank you for sharing/teaching!
« Reply #6 on: January 21, 2020, 07:39:42 pm »
I'm glad you like it.  ;)
Igorhmc
« Reply #7 on: April 15, 2020, 05:22:54 pm »
Best Regards.
Wow.. was that i want to!
Thanks a lot :) :)
Rzk
« Reply #8 on: July 28, 2020, 02:16:30 pm »
Hi Dragan,
I'm testing your amazing macro  :D
But the "Clipping Spline", doesn't seems to work for me... :'(
As mentionned in the Noted:
Inside the used macros, I reconnect* the Array 2S to the Transform  (like in your video:  https://youtu.be/QTGXqxQVI-E?t=728).
But I got the message: "No Geometry"
Am I missing something ?  ???
N.B: I'm using your own file, freshly extracted from the .rar
ಠ‿ಠ  Knowledge is power ಠ‿ಠ
« Reply #9 on: July 28, 2020, 02:46:48 pm »
Can you please send me a file so I can take a look.
I will try to upgrade the Macro so it can be switched from L1S to A2S just by a checkbox like in my blinds macro: https://www.youtube.com/watch?v=lqYXDpBw4pQ&t=11s
Rzk
« Reply #10 on: July 28, 2020, 02:56:41 pm »
Here is the incriminated max file.
Nice, I didnt even noticed you made another Blinds macro  ;D
Are you some kind of wizard ?!  8) :D
« Reply #11 on: July 28, 2020, 03:14:23 pm »
I cant see nothing wrong, everything opened well. All Railclone objects are fine here. Are you using RC4? :D ;D
Please make a print screen on the Master Genarator level so I can see where is the issue.
Thank you.
« Last Edit: July 28, 2020, 03:44:52 pm by Dragan »
« Reply #12 on: July 28, 2020, 03:22:52 pm »
Hahaha
No, since Itoo introduces a Macro option I usually go straight to Macro when I create a Style. That gives me more flexibility to expand Generator if needed. Then from time to time, I share some of those macros when I see people are asking for it.
Rzk
« Reply #13 on: July 28, 2020, 03:48:12 pm »
Thank you.
Using: Max 2017   with   RC 4.0.9  :-\
edit: Installed latest  RC 4.2.1,  now I can see 2D array macro  ;)
« Last Edit: July 30, 2020, 04:27:31 pm by Rzk »
« Reply #14 on: July 28, 2020, 04:20:36 pm »
Besides some material issues, RC object is Correct here.  ???
I will check it and upgrade it to the Generator Level. I see you are going for some more material options. I will try to make this more elegant.
I have been planning to make a more painful generator with various types of windows and doors for some time now.
« Last Edit: July 28, 2020, 04:48:57 pm by Dragan »
