Author Topic: railcone surfaces help  (Read 2536 times)
PS4115
« on: November 25, 2019, 03:25:26 am »
Hi Wondering if anyone can help with this footpath issue I am having.
I have created a sloping surface with I am trying to apply a 300 x 600 tile to via railclone 4.  Once the slope starts railcone is deforming the edges of the segment to the lowest Z point.
To create the slope I traced over the original footpath mesh which was export from a CAD model with a closed spline.
Converted that spline into a edit poly and then created a outline spline from the edit poly.
In railcone
I connected the outline spline to the spline node and the edit poly to the surfaces node.
Any advice on what I am doing wrong here.
3dsmax 2020.2
Railclone Pro 4
Forest Pro 6
Re: railcone surfaces help
« Reply #1 on: November 25, 2019, 07:39:53 am »
To work correctly, the RailClone object should be entirely enclosed by the boundaries of the surface. If the RailClone object overlaps a boundary, unwanted deformation might occur. Making the surface slightly larger (for example by using the Edit Polygons > Outline & Inset tools) is good practice to avoid any unwanted deformations.
PS4115
« Reply #2 on: November 25, 2019, 09:16:44 am »
Thanks Michal, that did the trick.
