Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Railclone can only inherit UVW channel 1 from geo?
« previous
next »
Print
Pages: [
1
Author
Topic: Railclone can only inherit UVW channel 1 from geo? (Read 2565 times)
Rio
Jr. Member
on:
April 18, 2023, 04:24:27 pm »
I'm getting some weird behavior, I was under the impression that if UVs weren't generated in the array then RC would pick them up from the segments, but at the moment that only seems to be working for channel 1.
Is this correct?
Logged
Rio
Jr. Member
Re: Railclone can only inherit UVW channel 1 from geo?
Reply #1 on:
April 18, 2023, 04:37:25 pm »
simple example, map is on channel 2
Logged
ITOOSOFT
Hero Member
Reply #2 on:
April 19, 2023, 01:43:59 pm »
It should work for any
Map Channel
. Can you please try using the
Display
Build
button to see if rebuilding all stored data fixes it? If you'll be able to reproduce it on a minimal scene, which you can
send us
, it would be great. Thanks in advance for any further comments on this issue you can share about it with us / our user community (in case some user(s) will run into similar troubles).
Logged
Rio
Jr. Member
Reply #3 on:
April 20, 2023, 01:59:07 pm »
You're right, it does work on a simple scene, there must have been something else going on.
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
