Author Topic: Railclone color not working?  (Read 3746 times)
DT
« on: December 03, 2021, 12:10:17 pm »
I have a railclone that scatters 5 vrayproxy cars. The carpaint of all 5 of them is an instanced VrayCarPaintMtl with a Railclone color map with 6 color swatches. Blending mode is set to normal.
For my license plates the same, but with 10 different textures.
Instancing Engine is on and use Segment Material is on.
Problem is there is no randomization at all. All the colors are the same and all the licenseplates are the same. Am I doing something wrong? Do I have to add a special node in my definition?
Thank you.
« Last Edit: December 03, 2021, 12:14:13 pm by VIZIOEN »
Re: Railclone color not working?
« Reply #1 on: December 03, 2021, 12:38:18 pm »
Hmm,
That's strange. I just did a quick test and RC Colour is working here as expected when scattering V-Ray proxies.
If you can reproduce it with a minimal scene and send it to helpdesk@itoosoft.com I'll take a close look.
Cheers,
DT
« Reply #2 on: December 03, 2021, 12:56:17 pm »
Hmm,
Cheers,
Yeah I find it strange too. I've uploaded the scene to wetransfer. Will send you by email. Thanks.
« Reply #3 on: December 03, 2021, 01:50:49 pm »
Thanks for the file. I've taken a look at a single car and it would appear the the paint colour is OK. The variations between them were quire tough to see so I added some more vibrant colours for testing purposes and all seemed OK.
For the number plates on the other hand it would appear the the checkboxes next to the maps were not activated.
Hope that helps,
« Last Edit: December 03, 2021, 02:05:51 pm by Paul Roberts »
RealViz
    • RealViz
« Reply #4 on: December 03, 2021, 02:04:09 pm »
I also ran into this behavior once (RCcolor). I think it was because the material was assigned after the RC object was created. However, it was enough to open the scene again. But I don't have confirmation of this.
DT
« Reply #5 on: December 03, 2021, 02:10:28 pm »
Hope that helps,
Hey Paul,
Thanks for the help, that is strange though, because these were the same colours I used in a ForestColor with these cars and same distribution and that was visible. As for the license plates, my mistake. Sorry.
DT
« Reply #6 on: December 06, 2021, 11:54:32 am »
Hope that helps,
Hi Paul,
I can't get this to work, I've removed all the other cars in the RC definition, except for one, I tried to replace the Railclone color map as well (with bright colors). I tried with Vraycolors instead of using the color swatch. It justs ignores the other colors/maps/swatches. It only takes the first one. No idea why it works in your case and not mine. Maybe there's a bug with this RC beta?
EDIT: I just updated my RC to the latest Beta, and it seems it's working now. Not sure if it was because the update or because (as Realviz stated as well) I had to close and reopen Max for it to work. Although this is unlikely as I closed and reopened Max a few times in the mean time.
« Last Edit: December 06, 2021, 12:05:40 pm by VIZIOEN »
« Reply #7 on: December 06, 2021, 01:42:37 pm »
Maybe that was it. Glad to hear it is working now in any case.
