Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Railclone Curb Slab does not curb
« previous
next »
Print
Pages: [
1
Author
Topic: Railclone Curb Slab does not curb (Read 4773 times)
BB5945
Newbie
on:
November 24, 2021, 01:49:23 pm »
Hi all,
as you can see attached, something goes wrong with curb drop. Any idea to solve this issue ? Thank you in advance.
(This is the default "Concret Curb & Gutter" settings of RC library)
Nicolas
Last Edit: November 24, 2021, 01:54:24 pm by BB5945
Logged
Hero Member
Re: Railclone Curb Slab does not curb
Reply #1 on:
November 24, 2021, 01:54:18 pm »
Hi, check the value on the Style tab under the Curve Steps and try to increase it to about 60.
Logged
BB5945
Newbie
Reply #2 on:
November 24, 2021, 02:10:58 pm »
Hi sir,
Thank you for your answer but It does not work :/
as you can see, the objects at the start and the end of the curb do not bend correctly....
Logged
Hero Member
Reply #3 on:
November 24, 2021, 02:13:49 pm »
check is there a Vertex there and try to change it to Smooth.
Logged
BB5945
Newbie
Reply #4 on:
November 24, 2021, 02:21:40 pm »
almost
and it changes the overall shape of the spline, that's not what I want
Logged
Hero Member
Reply #5 on:
November 24, 2021, 02:23:05 pm »
Can you share the scene file and if you can downgrade it to Max2020
Logged
BB5945
Newbie
Reply #6 on:
November 24, 2021, 02:28:39 pm »
In the style Editor, if I change "compose" parameter from Sequential to Grouped, the object bend correctly but it does a mess around
Logged
BB5945
Newbie
Reply #7 on:
November 24, 2021, 02:31:31 pm »
Max 2020 scene :
https://we.tl/t-gjZwQIDvFW
Logged
ITOOSOFT
Hero Member
Reply #8 on:
November 24, 2021, 02:32:07 pm »
This issue is likely to be related to the thread here:
https://forum.itoosoft.com/railclone-pro-(*)/drop-curb-problem-on-curved-line/
The drop kerbs have an issue on curved paths because of the way the spline is divided internally when using limit by material ID.
Ideally, we need to redo these using a different technique.
Logged
Hero Member
Reply #9 on:
November 24, 2021, 02:51:12 pm »
Yes. You could go with a workaround to use Selector on MaterialID and go with one Generator.
I`m not sure if this is gona work
I didn`t check it at all. It was just a 15-second fix, but it will give you an idea of how to solve it.
Last Edit: November 24, 2021, 03:04:06 pm by Dragan
Logged
BB5945
Newbie
Reply #10 on:
November 24, 2021, 03:01:25 pm »
Alright, thank you Dragan for your help !
and Paul thank you for sharing the file with the appropriate method !
Nicol
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
