Author Topic: RC Tiles Library - Small Plane Tiles with Decorative rows - problem  (Read 2741 times)
FC1888
Anyone know why this isn't working, all the other work just fine.
1) the materials are missing
2) it has only flat tiles, the decorative ones are missing
I have attached the max file and a screen shot showing the result I am getting
Also some of the edge styles, have the incorrect number of material entries, so matching them to a particular tile material, isn't possible, unless to increase the number in the style editor. but that I can live with. The above, I just cannot figure out why this one style is not working
Re: RC Tiles Library - Small Plane Tiles with Decorative rows - problem
« Reply #1 on: June 09, 2017, 11:07:32 am »
Big thanks for reporting these troubles. It seems to be linked to exported counters of the Sequence Operator. It'll need to be investigated more in deep by our main developers. Meanwhile, recreating the Sequence Operator should fix it.
FC1888
« Reply #2 on: June 09, 2017, 01:08:02 pm »
umm How to recreate the sequence modifier? (there are two of them) and of course there is the problem with it having no materials..
« Reply #3 on: June 09, 2017, 02:51:38 pm »
It looks like, the last version of the index.xml file located at:
C:\Users\<your username>\AppData\Local\Itoo Software\RailClone Pro\lib\default1\Architecture\Exterior\Roofing\Tiles
doesn't contain two following lines:
matlib>matlibs\rc_roofing_$(RENDERER).mat</matlib>
<material>_RC_concrete_and_terracotta</material>
Adding these will import the material. I'm attaching also the screen-shot showing the problematic Sequence Operator. Hope that helps.
Best regadrs,
« Last Edit: June 09, 2017, 02:57:26 pm by Michal Karmazín »
FC1888
« Reply #4 on: June 09, 2017, 04:07:11 pm »
ok sorted the index.xml file.. but now how do you adjust the parameters for the two different tiles, in max or is this just a temp fix, until it can be sorted fully...
Probably won't use this particular style much anyway, so not that big a problem for me. Only really noticed it, when I was playing around with the different style, checking them out
