RailClone => RailClone Pro (*) => Topic started by: Marksman on March 18, 2020, 01:57:15 am
While using Vray GPU IPR, the railclone objects disappear often. If I drag the spline a bit or change a parameter it will come bag. Any hints as to why this happens?
Actually this happens often even without Vray GPU IPR running
Hi, we made many changes in Forest and RailClone to support IPR, but since this render mode is not natively supported in Max, various problems may occur.
Would You please provide an example scene where this is happening without GPU IPR running.
