Author Topic: Running bond macro - corners problem  (Read 2473 times)
nubo
« on: April 09, 2021, 05:50:18 pm »
I was trying to use 'Running bond' macro and noticed that it breaks segments on corners.
Also, 'Swap course' checkbox doesn't seem to work.
I saw that brick walls preset created in this tutorial https://www.youtube.com/watch?v=1zY0GH0z4ig work great, so I will stick to that one for now, nonetheless it would be nice to have working macro for quicker workflow. :)
Scene and image attached
RC 4.2.1
Przemek
Re: Running bond macro - corners problem
« Reply #1 on: April 09, 2021, 10:51:02 pm »
As I remember this macro works only with 90deg corners and it was made for RC3 so it`s possible it will not work well due to some changes after migration to RC4 (https://docs.itoosoft.com/railclone/migrating-to-4-x)
Here is a quick start on how this could be solved. You can add Transforms operator and play around to get the results you wish.
Start with adding the Transform on the Default line to see the effects then try with Start/End/Corners lines.
