RailClone => RailClone Pro (*) => Topic started by: Adi S on October 26, 2019, 07:03:13 pm
Title: Railclone PRO object dissapears when collapsing to editable poly/mesh
Post by: Adi S on October 26, 2019, 07:03:13 pm
Hey guys , i need an urgent help with this. As mentioned in subject, my railclone object dissapears when collapsing to ediable poly or mesh. I tried also adding edit poly ,edit mesh and mesh select modifier and same thing happens.
Any help with this ?
https://www.dropbox.com/s/1cwgdklzl5ktzb4/RC%20problem.gif?dl=0
Title: Re: Railclone PRO object dissapears when collapsing to editable poly/mesh
Post by: Dragan on October 26, 2019, 09:01:45 pm
Check the display mode for RC. Try to set it to Mesh before applying a modifier or collapsing to editable poly or mesh.
Post by: Adi S on October 26, 2019, 10:17:33 pm
Thank you, it worked. I actually knew this already but I used Quick Mesh display mode which looks similar (or the same in my case) so I overlooked that possibility.
