Author Topic: spline Mtl ID problem  (Read 3173 times)
IS4550
« on: July 03, 2019, 01:59:12 pm »
I want to make a default stone curb with IDs 1 and 2*.
And when I change my spline Mtl ID to 2, curbe doesn't follow the spline? Did anyone had similar problems?
Thank you
« Last Edit: July 03, 2019, 03:13:43 pm by IS4550 »
Re: spline Mtl ID problem
« Reply #1 on: July 03, 2019, 03:08:18 pm »
Hi. Welcome to the forum.
We can take a look in Your situation only if You attached or shared Your files.
IS4550
« Reply #2 on: July 03, 2019, 03:21:08 pm »
Thank you, I have placed the max file in the attachment :)
« Reply #3 on: July 04, 2019, 10:16:18 am »
That's a limitation of using material IDs.
RailClone splits the spline so curves that bridge IDs are no longer a continuous smooth sweep.
You can check workarounds for this issue in this thread
IS4550
« Reply #4 on: July 04, 2019, 11:49:33 am »
Thank you very much for the response, it is much appreciated. :)
