Author Topic: Spider Glazing tutorial  (Read 4623 times)
LH2287
« on: December 13, 2017, 02:44:35 pm »
I am trying to use the Spider glazing tutorial files and modify them for my project. I want to extend the Xspline in order to have a longer facade, but it builds only to a certain point and stops after that, almost like something is limiting the X length of the facade. The Yspline length is working properly and the facade can be extended as desired. Is there any solution to this? I am using RC 3.0.9.
Best regards
Re: Spider Glazing tutorial
« Reply #1 on: December 13, 2017, 04:38:49 pm »
It sounds like, that such spline is being "limited" by the Base Objects > Properties > Start or Lenght value - enabling the Full Lenght option should fix it. Attaching screen-shot. Hope that helps.
LH2287
« Reply #2 on: December 13, 2017, 05:03:24 pm »
Thanks a lot. It seems there is always an option that is hiding somewhere. Worked perfectly.
Best regards
