Author Topic: Railing with stairs  (Read 8486 times)
NO4657
Railing with stairs
« on: August 21, 2014, 01:05:35 pm »
Can the stock railing be edited to do stairs with the railing running un-stepped to the ground?
Re: Railing with stairs
« Reply #1 on: August 21, 2014, 01:49:06 pm »
This can be done with a conditional statement and some spline IDs, as follows:
  • Set the stair spline segment's material ID to 2
  • Create a new Conditional operator and wire it to the Evenly input. Turn on Material ID and set it to Equal 2
  • Wire an Empty segment to the True input
  • Wire the existing compose operator to the False input
  • Select the generator and set the Properties > Rules > Default > Mode to Adaptive
I hope that helps,
let me know if you have further questions.
Many thanks,
« Last Edit: August 21, 2014, 01:58:26 pm by Paul Roberts »
