Author Topic: Random Rotation  (Read 5858 times)
Random Rotation
« on: June 04, 2018, 09:41:53 am »
I have new problem with random rotation.
1. Randomly rotate `light tubes` along Z/X axis - OK
2.  I have problem with "carrying straps". Cant make them to follow `Light tube`rotation and  force to stay vertical
any idea
Best regards
« Last Edit: June 04, 2018, 09:44:22 am by Dragan »
Re: Random Rotation
« Reply #1 on: June 04, 2018, 10:00:51 am »
Easiest solution- Your lamp should be one object:
You can make it from RailClone as well and nest it in another RailClone, but it should be one object.
Re: Random Rotation
« Reply #2 on: June 04, 2018, 10:13:01 am »
Yes I got that but Rotation along X is also random eg. 5 - 25 deg , then how to keep wires always vertical?
« Last Edit: June 04, 2018, 11:37:43 am by Dragan »
Re: Random Rotation
« Reply #3 on: June 04, 2018, 10:57:23 am »
I attach my nested solution:
Re: Random Rotation
« Reply #4 on: June 04, 2018, 11:36:52 am »
Thank You again Rokas, it is great solution.
I followed everything and all is clear but one operator. Can you please clarify why  Compose operator and Null segment?
« Last Edit: June 04, 2018, 11:38:43 am by Dragan »
Re: Random Rotation
« Reply #5 on: June 04, 2018, 11:44:38 am »
Null stops Default segments from repeating. I have set it to x = 100cm
Once rotated it becomes shorter (in top projection in x direction), so it gets repeated. We kill it with null segment.
Re: Random Rotation
« Reply #6 on: June 04, 2018, 12:10:29 pm »
Ok. Got it. Thank You.
