Author Topic: To stupid for that pattern....  (Read 2723 times)
IE4283
« on: June 20, 2019, 12:27:39 pm »
i am testing now for a while.... But I am to stupid to get that pattern done.
I build two bricks (the mash of each stone is a bit different).
The Stone is 21cm x 14cm.
Hope someone can help.
Thanks Florian
« Last Edit: June 20, 2019, 12:35:20 pm by IE4283 »
Re: To Stupid for that pattern....
« Reply #1 on: June 20, 2019, 12:38:58 pm »
Hi. Don't worry. Practice makes perfect.
We have a tutorial specifically to what You are building- Herringbone pattern.
If You are using few different meshes for the brick, You can make sure they are excactly the same size using transform Node fixed size setting:
Hope this helps!
IE4283
Re: To stupid for that pattern....
« Reply #2 on: June 20, 2019, 01:04:44 pm »
perfect answer. I made it  :)
THANKS again
