Author Topic: RC Corona Decal  (Read 20316 times)
arch3d
    • arch3d.pl
RC Corona Decal
« on: May 06, 2022, 11:13:19 am »
Is it possible to provide Corona Decal support by RC?
Best
Michal
Re: RC Corona Decal
« Reply #1 on: May 06, 2022, 02:56:48 pm »
Hi Michal,
Thanks for the question. Corona Decal currently doesn't return any size to RailClone which causes us several issues. We're looking into a way to work around it. On the other hand Corona Decals do work with Forest Pack which doesn't rely on the size to affect its distribution, however , the proxy display will not look right in the viewports. One solution for Forest Pack is to add an Edit Mesh modifier to the Corona Decal and then set it to off at render-time. In that way you'll get a clearer view of the distribution in the viewports.
I hope that helps,
arch3d
    • arch3d.pl
Re: RC Corona Decal
« Reply #2 on: May 10, 2022, 09:14:57 am »
Thank you!
I was thinking about play wit wire paramaters but i didnt try it. Ill play with FP
Thank you once again
Re: RC Corona Decal
« Reply #3 on: May 10, 2022, 09:21:24 am »
Hi Michal,
Just an update, we've added support for Corona decals to RailClone too now. It'll be available in the next update.
Cheers!
arch3d
    • arch3d.pl
Re: RC Corona Decal
« Reply #4 on: May 11, 2022, 01:19:48 pm »
Thank you!
BK8837
Re: RC Corona Decal
« Reply #5 on: October 06, 2024, 02:30:25 am »
Hello Itoo, Is there a way to see the CoronaDecal material on the Railclone object?
