Author Topic: RC slice pivot problem  (Read 8499 times)
RealViz
    • RealViz
« on: January 26, 2024, 08:56:45 am »
Hi, for some reason the Alignment at Start and End is ignored when set on Pivot. :-( I have a simple railing with Alignment Y entered on Pivot. Default segment works, Start and End unfortunately not. Is the error with me?
Thx
Re: RC slice pivot problem
« Reply #1 on: January 26, 2024, 09:45:16 am »
I've done some quick tests with the RC Slice modifier, but so far, I haven't been able to reproduce the mentioned problem here. Could you please send us the problematic scene? Thanks in advance.
RealViz
    • RealViz
« Reply #2 on: January 26, 2024, 10:21:21 am »
Hi, I'm sending a simplified scene. Maxver 2022.
I found that if the Pivot is in the original position, everything works. However, if I manually move the pivot, it stops working.
RealViz
    • RealViz
« Reply #3 on: January 26, 2024, 10:31:59 am »
« Reply #4 on: January 26, 2024, 12:49:24 pm »
Thank you very much for providing the scene. It will need to be thoroughly investigated by our main developers, and hopefully, a solution will be found soon. In the meantime, applying the Reset XForm in the stack just below the RC Slice modifier helps.
RealViz
    • RealViz
« Reply #5 on: January 30, 2024, 06:28:23 am »
Yes, or the extraction of the slice itself. But it all lacks the beauty of RC Slice when the whole history is preserved. Even with ResetXform, the history is a little bit broken :-(
« Reply #6 on: February 01, 2024, 01:33:11 pm »
It has already been fixed, and RailClone 6.1.6 was published a while ago, which includes the patch. I hope that helps.
RealViz
    • RealViz
« Reply #7 on: February 01, 2024, 05:25:49 pm »
Thanks! I downloaded it this morning and it works. Thanks again for the solution!
« Reply #8 on: February 02, 2024, 08:09:03 am »
You're welcome. I'm glad to hear that it's working fine now. ;)
