Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
RC as hypotenuse segment
« previous
next »
Print
Pages: [
1
Author
Topic: RC as hypotenuse segment (Read 3744 times)
arch3d
Sr. Member
on:
July 19, 2022, 01:46:21 pm »
Is it possible to use A1S as hypotenuse segment, or its RC limitation?
It works perfect with regular segments but i would like to avoid messing with Composites
Best
Michal
Last Edit: July 19, 2022, 01:50:40 pm by arch3d
Logged
arch3d
Sr. Member
Re: RC as hypotenuse segment
Reply #1 on:
July 19, 2022, 01:55:47 pm »
Here is example based on regular segment
Logged
ITOOSOFT
Hero Member
Reply #2 on:
July 19, 2022, 03:01:17 pm »
Hi!
Thanks for the question. It's possible, you just need to tell RailClone which generator in the chain you wish to use for the X Spline Length. You do it like this, using the name of the generator:
I hope that helps,
Logged
arch3d
Sr. Member
Reply #3 on:
July 19, 2022, 03:09:51 pm »
So simple! Easier way is always hard to find
Thank you very much:)
Logged
arch3d
Sr. Member
Reply #4 on:
July 19, 2022, 03:46:21 pm »
Something harder here:)
I put it into markers and have no idea from where is gap
Cheers
Logged
ITOOSOFT
Hero Member
Reply #5 on:
July 19, 2022, 04:43:04 pm »
Please find attached a revised version. I've just tweaked the trig expressions and few other things a little bit.
Hope it helps.
Logged
arch3d
Sr. Member
Reply #6 on:
July 19, 2022, 05:17:40 pm »
Works perfect
Thank you
Logged
arch3d
Sr. Member
Reply #7 on:
July 19, 2022, 06:27:00 pm »
I didnt notice it before sorry for that.
What if spline isnt flat?
I have to make a lot of trusses so it seems to be importnant as well.
Only solutution which I can find is make A1S segment verical vithout slope fixing
Cheers
Logged
ITOOSOFT
Hero Member
Reply #8 on:
July 20, 2022, 12:45:21 pm »
Is that solution working well enough? It might be possible to find the angle of the spline, but it could get quite complicated!
Best,
Logged
arch3d
Sr. Member
Reply #9 on:
July 20, 2022, 12:52:01 pm »
I will see on complex object. It might be ok. If you say its complicated i dont even think about it.
Many thanks its much more better than compose mode ( less distortion in vertical mode
Many thanks
M
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
