Author Topic: Some problems  (Read 16365 times)
ST3200
Some problems
« on: October 02, 2024, 01:28:23 pm »
I was trying to follow and tutorial from 6 years ago  ( https://youtu.be/vqS4ode_8gM?t=582 )
To have the grout of the floor, I need to check "overide fixed size",but it is not said in the video. Something have changed or there is a problem ?
I don't use usually box mapping in Rail clone, but I tried but I can't succeed, nothing happen ? Any idea ?
« Last Edit: October 02, 2024, 02:48:36 pm by ST3200 »
Re: Some problems
« Reply #1 on: October 02, 2024, 03:26:32 pm »
As you mentioned, the 'Mastering Procedural Modelling in 3ds Max' tutorial was recorded a few years ago, before the 'Override Fixed Size' checkbox was introduced. Which renderer are you using? You may need to disable the instancing engine to enable the Apply Box Mapping feature. I recommend checking the 'Feature Compatibility' table for further details.
ST3200
Re: Some problems
« Reply #2 on: October 02, 2024, 04:45:23 pm »
Thanks !  :)
