Author Topic: Unexpected Clipping Area behavior  (Read 4538 times)
IT1371
« on: August 31, 2017, 12:25:35 pm »
In Railclone 2 I could easily do the following:
1. Create a Clipping Area X or Y with exclusion.
2. Z Offset the Generator.
3. The segments will "build around" the Clipping Area, taking the offset in consideration.
See video attached:
https://vimeo.com/231844963
In Railclone 3 all it does is an offset and does not consider the Clipping Area.
See video attached:
https://vimeo.com/231844021
« Last Edit: September 01, 2017, 12:03:03 pm by 3dcrgr »
Re: Unexpected Clipping Area behavior
« Reply #1 on: August 31, 2017, 01:12:11 pm »
Big thanks for reporting this behaviour. Our main developers will have a look at it (it'll need to be investigated more in deep).
Best regadrs,
IT1371
« Reply #2 on: August 31, 2017, 03:05:22 pm »
Best regadrs,
Meanwhile I reverted back to 2.7.5, but now my scenes I made with 3.0.8 will not render.
Is there a way to save it rather then rebuild all the styles?
« Last Edit: August 31, 2017, 03:47:27 pm by 3dcrgr »
« Reply #3 on: August 31, 2017, 03:47:32 pm »
I'm afraid, we can't guarantee its full backward compatibility because of many new features, improvements and bugs fixed in any of published releases. Thanks for your comprehension.
I would suggest you to check the "Parse error" slightly related post on our forum: "There's a new Expressions syntax in RailClone 3. Expressions now require you to add a return property before the expression and a semi-colon (;)at the end of the line. Please feel free to check the "Converting RailClone 2 styles for RailClone 3" document, where you can find RC2 & RC3 differences."
Hope that helps a bit.
« Reply #4 on: August 31, 2017, 09:13:21 pm »
There is no backward compatibility ... main main few styles didn`t translate to RC3. I had to redo styles for RC3. And my main environment is still RC2.xx for my crucial style to be redone. I like RC3 a lot.
« Last Edit: September 01, 2017, 06:15:43 am by Rokas »
