Author Topic: RC Slice Modifier Output Bug?  (Read 10855 times)
Denis
« on: June 18, 2025, 05:49:06 pm »
Hi ItooSoftware-Team,
i just opened a project wich i´ve been working on just before the latest RC update. I used RC-Slice Modifier to select my "Default, Start and Evenly" segments within the railclone editor. I made a simple linear style to create some windows.
With the new update i found my RC windows to behave very weird, like every segments has some different height offset. On top of that, you can see the window parts, but you cannot select them.
Here is a screenshot and the file attached.
The red marked area shows the railclone window which uses the RC-Slice-Modifier Outputs, the other one uses the exported slices.
Would be great if you could investigate this problem. Many thanks in advance.
Denis
Re: RC Slice Modifier Output Bug?
« Reply #1 on: June 19, 2025, 12:07:13 pm »
Hi Denis,
Thanks for sharing the scene. We've reproduced the issue in the latest version, and our developers have already fixed it. The update should be released later today. We really appreciate your feedback.
« Reply #2 on: June 19, 2025, 01:51:10 pm »
Denis
« Reply #3 on: June 19, 2025, 06:48:55 pm »
Hi Michal,
thank you very much for the super fast update. Everything works fine now.
Denis
RealViz
    • RealViz
« Reply #4 on: June 25, 2025, 07:25:20 am »
Thanks!
I just opened the forum to post about this bug. I solved it with reset xform, but it was annoying.
