Author Topic: Spline from Autocad Problem  (Read 5673 times)
HU0164
« on: November 21, 2025, 09:25:32 am »
I receive 2D AutoCAD DWG files from surveyors.
I am almost never able to apply a RailClone object to splines from DWG files.
What do I need to do to make it work?
Re: Spline from Autocad Problem
« Reply #1 on: November 21, 2025, 09:32:42 am »
I'm sorry to hear you're having trouble with it. Could you please describe the issue in a bit more detail? Are the RailClone styles you're using based on the spline’s Material IDs? If so, let me mention that, as noted here on our forum:
"... upon my experience, in case of importing splines from a .dwg file, its Color is used for generating the 3ds max Material ID. If you want to avoid the Edit Spline modifier step - assigning the Red color to such spline (layer) should result in ID 1 / Yellow as ID2 (as the Red color should be indexed 1 (Yellow 2) in AutoCAD)."
HU0164
« Reply #2 on: November 21, 2025, 09:56:46 am »
Yes, that's right.
I can't integrate this parameter into my head. It must be old age.  :)
