Author Topic: X-ref objects  (Read 3283 times)
JTP Vis
X-ref objects
« on: March 02, 2022, 03:24:30 pm »
Hi, I recently updated to the latest railclone, and it has stopped one of our custom library pre-sets working. The thing that makes this library item different from others that are still working correctly, is that the RC item uses x-ref object segments. Am I missing something, or have x-ref objects become not supported?
thanks,
Bill
Re: X-ref objects
« Reply #1 on: March 02, 2022, 03:26:51 pm »
Hi Bill, would it be possible to send the suspect library to helpdesk@itoosoft.com so we can check it? In theory XRefs should work OK.
Cheers,
JTP Vis
Re: X-ref objects
« Reply #2 on: March 02, 2022, 05:13:54 pm »
Hi Paul,
I've done my best to share the library and associated files etc. Please let me know if it works, or if you're missing anything.
Bill
JTP Vis
Re: X-ref objects
« Reply #3 on: April 25, 2022, 05:02:04 pm »
Hi Paul,
Is there any update on this issue with using x-ref objects in Railclone library objects? It's quite frustrating it not working.
Cheers,
Bill
Re: X-ref objects
« Reply #4 on: April 25, 2022, 05:15:25 pm »
Hello Bill,
According to the release notes the new beta has fixed "Library doesn't import Segments using XRef objects."
Please let me know if that's working for you.
Best,
