Author Topic: sequence cause overlaps at corners  (Read 3084 times)
Ken Turner
    • My Website
« on: July 19, 2021, 11:54:25 pm »
I'm working on a simple pipe creator using a linear 1s node. The setup is in adaptive mode and has filleted corners
I'd like to use a sequence node to create options for the straight parts of the pipe.
The issue is the sequence node creates nasty overlaps at corners.  ... and seems unusable / buggy
There is a max 2022 file if anyone has ideas
Ken Turner
VFX supervisor
Re: sequence cause overlaps at corners
« Reply #1 on: July 20, 2021, 12:17:38 am »
You can try nesting...
« Reply #2 on: July 20, 2021, 10:29:33 am »
Thanks for answering Dragan, that's generally a good solution. Just to explain why you get the issue. Adaptive mode only works if all of the segments are the same length on the X-axis.
Another alternative is to scale just the segment nearest the corner using the Scale Final X Segment macro. Demo file attached in case it's of interest.
Ken Turner
    • My Website
« Reply #3 on: July 20, 2021, 10:46:09 pm »
many thanks for your help .
Ken Turner
VFX supervisor
