Author Topic: Renaming nodes  (Read 2604 times)
Rio
Renaming nodes
« on: July 20, 2021, 04:17:24 pm »
When I attempt to rename a geometry node it is veeeery slow to update, and seems to delete characters after they're typed so I get a load of nonsense in the node name. Is there just a simple method or script available to update all node names to match the geoetry names? It's rare that I bother to name a segment something sensible when I'm first layout out the building blocks for a railclone object.
Re: Renaming nodes
« Reply #1 on: July 20, 2021, 04:45:58 pm »
I noticed the same thing in the latest version. I thought it was because of my complex styles but it seems to be something at the RC core after all.
I just disable it temporarily...
Rio
Re: Renaming nodes
« Reply #2 on: July 20, 2021, 05:36:48 pm »
Sorry Dragan, what did you disable? is it some auto renaming option?
Re: Renaming nodes
« Reply #3 on: July 20, 2021, 06:21:17 pm »
First of all, do you need to reload/rename segments nodes to match original inputs? If that is the case then use Reload Button.
If you have problems renaming other nodes then Disabling Object can help.
Rio
Re: Renaming nodes
« Reply #4 on: July 21, 2021, 06:30:21 pm »
Thanks a lot, that worked a treat. Again, I'm asking question about basic functionality, so thanks for your time! I'll get there one day.
