RailClone => RailClone Pro (*) => Topic started by: DrieDeeGraphics on June 08, 2015, 12:33:30 pm
Title: Render problems Railclone
Post by: DrieDeeGraphics on June 08, 2015, 12:33:30 pm
Hi there,
I'm having an problem with rendering a railclone object.
The scene is rendered with vraysun en physical vray cam.
but there is a strange moire effect / shadow on the geometry.
Does anyone have an idea what it might bee or got the answer to this problem.
Ill incl a max scene so you can test is for you're self.
Tanks..
Gr Peter
Title: Re: Render problems Railclone
Post by: Paul Roberts on June 08, 2015, 01:30:23 pm
Hi Peter,
I don't think this is a RailClone problem because if you convert the RC object to instances using RailClone tools or convert it to an editable poly the issue still persists.
Try reducing the V-Ray Sun's Shadow Bias value to 0.01, this seems to remove the moire pattern. I suspect it's something to do with the scale of the scene but I'm not sure.
Post by: DrieDeeGraphics on June 08, 2015, 05:11:35 pm
Hey Paul,
Tanks for the input, that seams to be the problem.
Many tanks for the fast reply an answer.
Gr Peter
