Author Topic: Reverse Normals  (Read 3397 times)
Bobby Parker
Reverse Normals
« on: February 14, 2019, 07:05:46 pm »
Reverse normals are failing. I can reverse, close MAX, and do it again once I open the scene back up, but that seems to be the only way.
https://youtu.be/z2z7IsMKfbY
Re: Reverse Normals
« Reply #1 on: February 15, 2019, 08:54:26 am »
Please attach Your scene so we can check it. Thanks!
Bobby Parker
Re: Reverse Normals
« Reply #2 on: September 28, 2022, 08:47:52 pm »
Years later, this is still an issue, making me not use Railclone unless I have to. I can't reverse splines.
Re: Reverse Normals
« Reply #3 on: September 29, 2022, 09:39:39 am »
In situations where reverse appears to have no effect, please try changing the first vertex to fix it. I generally start by moving it to the bottom left corner.
Cheers!
« Last Edit: October 07, 2022, 05:59:15 pm by Paul Roberts »
Bobby Parker
Re: Reverse Normals
« Reply #4 on: October 07, 2022, 05:57:36 pm »
I'll give that a try; thank you.
