Author Topic: Roof Macro - rotation  (Read 18405 times)
Ricousto
« on: October 16, 2024, 04:36:02 pm »
Hello
Crap !
Beginner's question
I'm using Roof Macro and I can't see how to rotate the slates?
(See attachment)
Thank you
Re: Roof Macro - rotation
« Reply #1 on: October 17, 2024, 09:21:07 am »
The 'Roof Tiles' macro uses the 'X → XY' Auto Align mode. However, if you switch to the 'to Spline' mode, the X-axis will align with the first spline segment. You can then adjust the alignment by using the 'Make First' vertex option or by reversing the spline as needed.
Ricousto
« Reply #2 on: October 17, 2024, 10:56:28 am »
Thank you for your reply.
That's what I thought, and I've tried, but unsuccessful.
The slates line up, but not the way I want them to.
(sorry, this is an old version of max!)
« Reply #3 on: October 17, 2024, 11:31:14 am »
It appears to be correct - the issue lies with the size of the tiles used. Scaling them down, for instance, by adjusting the Global Scale under Style > Geometry, allows these tiles to be placed in the way you want.
Ricousto
« Reply #4 on: October 17, 2024, 11:48:53 am »
ok thank you !
I thought I could vertically translate the slates but It's ok with the global scale.
