Author Topic: Use more than 1 surface - possible?  (Read 10569 times)
Morne
« on: April 22, 2022, 02:09:29 pm »
Hi Guys
How do I use more than 1 surface?
I have a fence spanning terrain, and the terrain is made up of various bits and the fence should follow all of it...
As a workaround, I could copy all terrain components and attach it into 1 and set it to not render, and use this dummy object as my surface, but the terrain already has couple million vertices as is
Re: Use more than 1 surface - possible?
« Reply #1 on: April 25, 2022, 02:02:54 pm »
Hi Morne,
I'm afraid at present only one surface can be used. As you've identified, if you need to keep the originals separate then the workaround to handle that at the moment is to combine them as a non-renderable dummy object. The ability to add multiple surfaces is on our wish list though!
Best,
Arslan
« Reply #2 on: July 16, 2024, 01:31:03 pm »
Is there a plan for the ability to add multiple surfaces? I couldn't update it because my maintenance program ended, maybe it has already been done, I'm asking because I can't see it as far as I follow the changelogs. It can be very necessary in some projects.
Best regards.
« Reply #3 on: July 16, 2024, 01:56:34 pm »
Thanks for the question. At present support for multiple surfaces is not available in RailClone. I'll add your vote!
Best,
