Author Topic: Rotate and move whole RC object in spline  (Read 6332 times)
MH4288
« on: September 04, 2018, 03:06:28 pm »
I have this problem often. Make a rectangle and apply RC on it with some style, but RC rotated wrong. Or its aligned to bottom line and I want to move RC little bit. Is there a way how to do that?
In Floor Generator plugin its really easy to do that. Is there some way please?
Thank you.
Re: Rotate and move whole RC object in spline
« Reply #1 on: September 04, 2018, 06:39:24 pm »
You can use expand and Z rotation.
Sometimes You will need to add transform operator also.
MH4288
« Reply #2 on: September 05, 2018, 10:47:26 am »
But in complex style, where I have to put it? I will then put it everywhere? Its to complex for just that simple operation I think.
« Reply #3 on: September 05, 2018, 10:55:54 am »
It is just another transform operation. Depends on the style. Please attach a style which gives You trouble and we will try to help You.
MH4288
« Reply #4 on: September 05, 2018, 12:30:06 pm »
For example Plank Cladding 1 or Cathedral Pantile in Rufing section.
MH4288
« Reply #5 on: September 05, 2018, 03:42:17 pm »
Please I need to know how to rotate roof tiles style in 90 degrees.
« Reply #6 on: September 06, 2018, 09:20:35 am »
To rotate style 90 degrees, please do following:
Edit current macro:
And next step to rotate it 90:
Hope that helps.
MH4288
« Reply #7 on: September 06, 2018, 04:03:54 pm »
Ok, thank you.
And what about moving whole style in rectangle in X or Y please?
« Reply #8 on: September 06, 2018, 04:46:08 pm »
Sure,
add transform operators, and increase Clipping Area Expand option so mesh is bigger than just clipping area, (not that hard- took about a minute):
Hope that helps
MH4288
« Reply #9 on: September 07, 2018, 11:49:17 am »
I am sorry, but I am not sure what you do here for move in X and Y.
And now I have a problem with a roof style on nonrectangular shape. There is a verge on one side, but its little bit sliced by a spline on that side. And its very hard to move points of spline to exact position so verge is not cropped.
Thank you and sorry for problems.
« Reply #10 on: September 07, 2018, 01:03:00 pm »
OK, attached a modified macro
Hope that helps
MH4288
« Reply #11 on: September 07, 2018, 01:20:51 pm »
Ok, thank you, I will look at it.
And please, is there something I can do to disable slice of verge?
Thank you again.
« Reply #12 on: September 07, 2018, 02:31:14 pm »
You can adjust this property in segment settings:
