RailClone => RailClone Pro (*) => Topic started by: funk24 on October 24, 2018, 10:42:25 am
good day
sorry for my bad English.
I have an array 2s object. the default object I would like to change the rotatin without changing the position. The distance in the axis should always be the same.
Is that possible?
If you define the General > Fixed Size of used Segment, having the Scale Segment option disabled, you can adjust under Transform > Rotation without affecting the distance of these “rows”.
Hope that helps.
Thank You. :)
