Author Topic: same random id in default and compose  (Read 2598 times)
MariOSc
« on: November 12, 2021, 07:26:55 pm »
Hello :)
I need your help ;D . I am trying to make the default random ID the same for the compound segments in corners and evenly to later use a coronamaterial with multimap.
THANK YOU FOR THE HELP
Re: same random id in default and compose
« Reply #1 on: November 12, 2021, 08:06:28 pm »
You can try nesting.
I`m not sure how you want to solve corners so I just add the Start segment as a corner element.
« Reply #2 on: November 12, 2021, 08:24:54 pm »
Sorry, I just look over at the picture.
I think this one is the right. You can play with the constant numeric parameter Left Padding to get wanted spacing.
« Last Edit: November 12, 2021, 08:33:19 pm by Dragan »
MariOSc
« Reply #3 on: November 12, 2021, 09:24:23 pm »
thank you this is just what I need  ;D. your first answer also helped me to give me an idea of how to solve it. each panel should be 450mm so now I'll see how I solve it.
« Reply #4 on: November 12, 2021, 09:39:05 pm »
You just play around with the evenly parameters.
When you place the segment to Corner, Evenly or Marker input RC will automatically split the spline into sections. Then you have each Section acting as a single spline so you can nest a new generator with X size equals SegmentSize of Master Generator.
I have exposed you some parameters that should help you set the right distribution.
Let me know if you need more.
You can also check some documentation about evenly distribution.
https://docs.itoosoft.com/railclone/next-steps-with-railclone/7-master-spacing-modes
Best Regards
« Last Edit: November 12, 2021, 09:47:08 pm by Dragan »
MariOSc
« Reply #5 on: November 13, 2021, 01:00:05 am »
Thanks master everything was very helpful  ;D. I must learn too much .
« Reply #6 on: November 13, 2021, 08:24:32 am »
Glad to help.
One step at a time, you will master it. I can see you already understand a lot!
Just go through all tutorials on Itoo official page and check out the forum`s topics.
